trouble with dowloading
***Topic moved***
Hi kluelos
- First of all ..Thank for your Brownser which I have been using for over 4 years without any problems at all .However , recently ,I had a trouble of downloading as DOWNLOADS box just pop up and downloading what I demanded and did not open fully to screen and i had to double click on the item in the Download box to open it out .
Before that when I downloaded something then this box will appear as :
Opening (.....).pdf
You have chosen to open
(....).pdf
which is a : Adobe Acrobat Document
What should Cometbird do .......?
.Open with A.R 0.3 (default)
Save file
Do this automatically.....
I got tire of this problem then I downloaded the Mozilla Firefox Brownser in order to get what i want .
Please , help me to fix this problem .
- Second of all , what's the difference beetwen Cometbird and Firefox Brownser ...?
Thank you so much
Edited by greywizard
Posted in wrong section (see edit history)
Guest
Reply to this topic...
  Only 75 emoji are allowed.
