Is it possible..
Yes, it's possible. Add the torrent you're downloading from to the other client and direct it to download where you've previously downloaded. The new client should do a "hash ckeck" and see how much is downloaded and what's left and then should begin to download again.
However, I don't think it will help. If you're stuck, then try a manual hash check with bitcomet. Then, there should preferbly be at least one seed for the torrent or some peers. In short, there might be no one that have the part of the file(s) you're trying to download. Be patient.
