Seeds:1(Max. possible:1)
Hi, what does this mean: Seeds:1(Max. possible:1)
a. there is currently only one seeder available for this torrent or maybe,
b. the tracker is allowing only 1 seeder for each peer for current torrent?
or something else. i was just wondering, thanks :unsure:
Hmm I have similar thing. Torrent has like 100+ seeders but it connects only to 1 and then goes back to 0 and doesn't download at all.
It's working with uTorrent. Also it's quite intresting that it didn't work like for 2 days but then started to work again yesterday and now it's not working again.
Seems to work with torrents from regional trackers.
Bitcomet 1.19( had the older version when it started)
ADSL
Thompson ST546 v6
Windows Vista, no AV, Windows FW with exceptions
No speed related issues just that it wont connect to peers outside my country with BitComet.
The tracker cannot "allow". It merely reports how many seeds have currently registered with it. Your client is telling you that it knows of 1 seed from all sources, and that you are connected to 1 of those seeds. "Max possible" means how many there are in the swarm, that you could connect to. In this case you're connected to all that there are.
janist, please don't jump into the middle of someone else's topic like this. Start your own.
