Not Seeding
MXMG
I have a 1Gbit seedbox and a couple of 100Mbit seedboxes. I upload any torrent to the seedbox and then I publish it so that thousands can download @ very high speeds.
I was using utorrent and came up with Bitcomet. But the problem is it isn't working right. No seeding or connecting to a peer(seedbox). But any other clients utorrent and bittorrent detect the seedbox and they start uploading where bitcomet just stay idle..
HELP!
I'm sure that the picture is very clear to you but it's not the same for us. So try to elaborate a little.
You need to explain what's your setup a bit.
What OS does your PC use? How about the seedbox?
What version of BitComet are you running? Is it running on the seedbox and and your PC as well (i.e. if your seedbox is running on Windows) or just on the seedbox and you use an alternate protocol (e.g. FTP/HTTP for retrieving/uploading the files between the seedbox and your PC)?
How do you access the remote client on the seedbox (i.e. through what protocol/application)?
Does this issue occur for any torrent or just some of them?
Are they private torrents or public ones?
Do you mean that the client running on the seedbox doesn't connect to peers or what?
