Connection with 1.31 help!
Sorry tech, I will post here maybe its the right spot..... I am new to this forum but not new to bitcomet. I have been an avid bitcomet user for many years, and never had a connection issue. Now i do. I downloaded the new Bitcomet 1.31 and It says it won't connect. Can anyone help? I am running windows Vista Home Basic 32-bit and I have DSL. maybe The settings are wrong? I dont know. I just downloaded the 1.31 version and haven't changed any other settings. Could it be a problem with the Port Detection Failed? or can i just revert back to the old bitcomet?
(Edited at 03:53 AM)
I get Port Detection Failed now.
I am new to this forum but not new to bitcomet. I have been an avid bitcomet user for many years, and never had a connection issue. Now i do. I downloaded the new Bitcomet 1.31 and It says it won't connect. Can anyone help? I am running windows Vista Home Basic 32-bit and I have DSL. maybe The settings are wrong? I dont know. I just downloaded the 1.31 version and haven't changed any other settings. How can i fix this? never had a problem before. Or should I try to revert back to my old bitcomet? and how?
Guest
 Share
