I need help improving Upload speed to peers
Hi,
This topic may have been posted by some other memebers, but i couldn't find one that matches with what i have to say. So here it is. I currently have a lot of completed torrents and would like to seed them. I've been using bitcomet for a while so i know the basics ie. More upload speed = more download speed. But the problem i'm having trouble trying to improve my upload rate to peers. At times i was able to upload 5k to 7 peers for say. Does anyone in this forum, could help me improve my upload rate to peers. I also tried turning off widows firewall, but that didn't show much progress as when it is on.
Do you know what upload speed your ISP gives you?
There is no way to upload faster than whatever they provide.
Read through the Settings Guide it will help you figure out how to maximize your speeds
The key to squeezing the most out of your limited upload capacity is to reduce overhead
To reduce overhead you must reduce the number of connections that Bitcomet makes
