Tallysrfr Posted August 3, 2010 Share Posted August 3, 2010 Why does torrent list show I'm uploading 16kb/s, but total is over 200 and torrent share is disabled? Where is the data going? How can I find out? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 3, 2010 Share Posted August 3, 2010 include the required info and we'll be glad to help you. Also, what little info you did post is confusing, like "200" what??? Link to comment Share on other sites More sharing options...
Tallysrfr Posted August 3, 2010 Author Share Posted August 3, 2010 I am using BitComet 1.22,windows xp,avg antivirus,zonealrm firewall,cabel modem. The upload speed varies, but it is more than the total of my torrent list. Once I was uploading 16kb/s on only one torrent, but the total upload was 246 kb/s. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 3, 2010 Share Posted August 3, 2010 bitcomet 1.22 has ability to connect to peers via traditional bittorrent sources, or also download the data from ftp/http, emule, or Longterm seed connections from other bitcomet peers. If you enabled the LTseed option, then your stopped tasks will make use of any unused bandwidth to upload to other peers. You can limit to maximum amount of upload that LTseeds use if you find the upload is interfering with your other usage, or you can disable the feature completely. Many users find that LTseed option greatly improves their download performance, but the actual benefit would depend on the number of bitcomet peers in any given torrent that have it enabled. Link to comment Share on other sites More sharing options...
Tallysrfr Posted August 3, 2010 Author Share Posted August 3, 2010 Okay,that's it. I was afraid I was getting hacked! LOL! Thanks for the help. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 4, 2010 Share Posted August 4, 2010 Your welcome Link to comment Share on other sites More sharing options...
