neon5 Posted January 23, 2012 Share Posted January 23, 2012 Hi ive been using bit comet for a couple of years now and since i have rebooted my windows i seem to have developed a qwerk with bit comet. I can't seem to log into the lower window pane with my comet i.d although both the user name and password are correct. Im running windows 7 64 bit and bit comet 1.29. My i.d is rapter97@hotmail.com. Any ideas any 1? Quote Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted January 23, 2012 Share Posted January 23, 2012 Your comet id and email address are two separate things, I suspect you're trying to use the wrong login. Try going to cometID.com and logging in. If your name and password are correct, you should have no problem. Quote Link to comment Share on other sites More sharing options...
neon5 Posted January 23, 2012 Author Share Posted January 23, 2012 lmao doh! i feel dense but thx sorted the problem. Quote Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted January 24, 2012 Share Posted January 24, 2012 No problem, it's nice when a problem is this easy to solve :) Quote Link to comment Share on other sites More sharing options...
