indialfa Posted September 3, 2013 Share Posted September 3, 2013 (edited) Hola, tengo el Bit Comet 1,35 y en "Capturas de pantalla" cuando clico en lugar de fotos sale un recuadro con la X en la esquina Hi. I have BitComet 1.35 and under "Screeshots", when I click [on it], instead of pictures, a box with an "X" in the corner appears. Edited September 5, 2013 by cassie (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 3, 2013 Share Posted September 3, 2013 (edited) Hi. If you are wondering why the screenshots don't instantly appear, it takes time to download them, or if you are using an IP filter it could be blocking the server. Also, if you are the first bitcomet peer with the option enabled there will be no screenshots available until the download completes. If you are referring to screenshots provided with the torrent that you're trying to view, you will have to finish downloading them before they can be viewed. Hola. Si te estás preguntando por qué las capturas de pantalla no aparecen de forma instantánea, te diré que tardan un poco en descargarse, o si estás usando un filtro de IPs, puede que éste esté bloqueando el servidor. También, si eres el primer par de BitComet con la opción habilitada, no habrán capturas de pantalla disponibles hasta que la descarga finalice. Si, por el contrario, te estás refiriendo a que estás intentando visualizar las capturas de pantalla que vienen incluidas con el torrent, tendrás que terminar de descargarlas, antes de poder verlas. Edited September 5, 2013 by cassie (see edit history) 1 Link to comment Share on other sites More sharing options...
indialfa Posted September 7, 2013 Author Share Posted September 7, 2013 (edited) ...Pues antes se veían, incluso sin haber descargado nada de la peli,...Gracias. ... well, before, I could see them, even without having downloaded any part of the movie... Thank you. Edited September 8, 2013 by cassie (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 7, 2013 Share Posted September 7, 2013 (edited) ...Pues antes se veían, incluso sin haber descargado nada de la peli,...Gracias. This is why I said... if you are the first bitcomet peer With The option enabled there will be no screenshots available until the download completes. If this task has been downloaded or authored by a bitcomet client the snapshots will be available. If you're the first bitcomet peer to complete the download, you will provide the snapshots when the task completes and they will be available for the next bitcomet peer. Por eso dije... si eres el primer par de BitComet con la opción habilitada, no habrán capturas de pantalla disponibles hasta que la descarga finalice. Si esta tarea ha sido descargada por un usuario con BitComet, las fotos estarán disponibles. Si tú eres el primer par/usuario que completa la descarga, tú serás quien proporciona las mismas cuando la tarea termine y estarán disponibles para el siguiente par que use Bitcomet. Edited September 8, 2013 by cassie (see edit history) Link to comment Share on other sites More sharing options...
