TCP connection overflow
first...sorry for my english...is translation by google
Client:  Bitcomet 1.49
by longer idle time. the tcp connections can bump up to over 9000 (also in zero torrent active)
my setting problem or software problem?
Up Time:    0:00:15
Overall Tasks:    Total: 0 / Running: 0
TCP Connections:    Established: 43 [MAX:Unlimited] / Half-Open: 0 [MAX:200]
LAN IP:    -------------
WAN IP:    -------------
Listen Port of TCP:    ----- (Opened in Firewall/Router)
Listen Port of UDP:    ----- (Opened in Firewall/Router)
Windows Firewall:    Disabled
UPnP NAT port mapping:    Disabled
Disk Boost Service:    Not Installed
Overall Download Rate:    4 kB/s [MAX:Unlimited]     Max Connection Limits: 9999 per task
Overall Upload Rate:    1 kB/s [MAX:Unlimited]     LT Seeding: 0 kB/s [MAX:Unlimited]     All BT Upload Slots: 0
Memory Usage:    Working Set: 121.46 MB, Commit Size: 74.13 MB
Free Memory:    Physical: 55.44 GB/63.93 GB (Min to keep: 50 MB), Virtual: 53.75 GB/63.93 GB, Process: 127.96 TB/127.99 TB
Disk Cache Size:    0 B (Min: 4096 MB, Max: 16384 MB)
Disk Read Statistics:    Request: 0 (freq: 0.0/s), Actual Disk Read: 0 (freq: 0.0/s), Hit Ratio: 0.0%
Disk Write Statistics:    Request: 0 (freq: 0.0/s), Actual Disk Write: 0 (freq: 0.0/s), Hit Ratio: 0.0%
Total Downloaded:    92.54 GB (this session: 64.28 KB)
Total Uploaded:    122.69 GB (this session: 25.19 KB)
Up Time:    1:02:53
TCP Connections:    Established: 1800 [MAX:Unlimited] / Half-Open: 0 [MAX:200]
LAN IP:    ----------
WAN IP:    ---------
Overall Download Rate:    18 kB/s [MAX:Unlimited]     Max Connection Limits: 9999 per task
Overall Upload Rate:    2 kB/s [MAX:Unlimited]     LT Seeding: 0 kB/s [MAX:Unlimited]     All BT Upload Slots: 0
Memory Usage:    Working Set: 181.89 MB, Commit Size: 162.78 MB
Free Memory:    Physical: 52.98 GB/63.93 GB (Min to keep: 50 MB), Virtual: 51.09 GB/63.93 GB, Process: 127.96 TB/127.99 TB
Total Downloaded:    33.25 MB (this session: 32.60 MB)
Total Uploaded:    5.11 MB (this session: 4.89 MB)
Edited by anime5167 (see edit history)
after 2hour..and runing one torrent
the torrent only have 0/113(seeding)
but connect is come up 1307...why
Up Time:	2:44:27
Overall Tasks:	Total: 1 / Running: 1
TCP Connections:	Established: 1307 [MAX:Unlimited] / Half-Open: 35 [MAX:200]
Overall Download Rate:	80 kB/s [MAX:Unlimited]     Max Connection Limits: 9999 per task
Overall Upload Rate:	17261 kB/s [MAX:Unlimited]     LT Seeding: 0 kB/s [MAX:Unlimited]     All BT Upload Slots: 110
Memory Usage:	Working Set: 16.19 GB, Commit Size: 16.18 GB
Free Memory:	Physical: 38.78 GB/63.93 GB (Min to keep: 50 MB), Virtual: 36.90 GB/63.93 GB, Process: 127.95 TB/127.99 TB
Disk Cache Size:	16 GB (Min: 4096 MB, Max: 16384 MB)
Disk Read Statistics:	Request: 14485650 (freq: 1013.2/s), Actual Disk Read: 62557 (freq: 6.0/s), Hit Ratio: 99.5%
Total Downloaded:	93.44 GB (this session: 917.81 MB)
Total Uploaded:	360.44 GB (this session: 237.74 GB)
after few minute is come up 1647 (seeding @ 0/107)
  • 3 weeks later...
the peer numbers of 0/xxx  means o seeds and xxx peers. If a peer disconnects and reconnects they are counted again as bitcomet doesn't count only actice peers, but the important number is the seeds, with zero seeds it will never download.
