joekor Posted March 10 Share Posted March 10 Hello there, I have difficulty setting up the DL and UL speed for Bitcomet from my internet carrier. My UL speed is 490Mbps and UL speed is 540Mbps from speed test. I run 5 torrents at a time, it is always frozen when it reach 99.99%. Sometime the program will "not responding". When i stop some task it will show "yellow" and hold a for a while. My PC is an I7 with 10700 CPU 2.9 Ghz, 16 RAM and 64 bit Windows 10 system. Beside the setting for speed, any other setting i need to setup , please advise. Thank you. Link to comment Share on other sites More sharing options...
Rhubarb Posted March 10 Share Posted March 10 That's an issue that cropped up recently and has been reported to the devs. We're just going to have to wait until they look into it and (hopefully) fix it. Short term - exit the progrem (from the menu bar) and when it's completely stopped, restart it. In most cases that will kick in the download for the final few bytes Link to comment Share on other sites More sharing options...
joekor Posted March 10 Author Share Posted March 10 get it,thx Link to comment Share on other sites More sharing options...
