adri_foro Posted June 13, 2011 Share Posted June 13, 2011 Please i need encode a video with the next especificacion: --------------------------------------------- Format : MPEG-TS OverallBitRate/String : 3500 Kbps ----------------------------------------- Video Format : MPEG Video Format_Version : Version 2 Format_Profile : Main@Main Format_Settings_BVOP/String : Yes Format_Settings_Matrix/String : Default Format_Settings_GOP : M=3, N=12 BitRate_Mode/String : CBR BitRate/String : 2910 Kbps Width/String : 720 pixel3 Height/String : 576 pixel3 DisplayAspectRatio/String : 4:3 FrameRate/String : 25.000 fps3 Standard : PAL ColorSpace : YUV ChromaSubsampling : 4:2:0 ---------------------------------------- I'm encoding with "Super" but do not know what parameters to use ... you recommend me another encoder or this is good? if so, which use parameters to adjust my specifications? thanks Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted June 13, 2011 Share Posted June 13, 2011 Mpeg transport stream is usually used when broadcasting video. It can better deal with damaged or degraded stream then traditional encoding containers such as dvd and more modern methods such as divx/xvid or h264/x264. Normally the exact settings used are based on the source video, so it's very odd to say you want to know how to encode a video with this exact specs, as they could completely destroy the video source if they aren't compatible. I think your question would be better asked if you specified what source video your using and what you plan to do with it, then perhaps members could offer advice on the best way to go about it. Link to comment Share on other sites More sharing options...
greywizard Posted June 13, 2011 Share Posted June 13, 2011 CCE is one of the best and is being used even by professional studios. Link to comment Share on other sites More sharing options...
