amarsi Posted May 24 Share Posted May 24 Norton 360 firewall blocks connection to BitComet 1.87 and above all does not allow connection to the tracker. It has deleted BitComet from the list of authorized programs and does not allow it to be re-entered (by error). If you reinstall BitComet when you launch the program, the Norton 360 firewall changes the rules and does not allow connection with the BitComet server. The only solution is to block the firewall, but it is a very risky solution. So are BitComet and Norton 360 incompatible? Quote Link to comment Share on other sites More sharing options...
Rhubarb Posted May 25 Share Posted May 25 It's a known issue with some AV apps. Turn the AV off during install and fhen turn it back on after Check this post Quote Link to comment Share on other sites More sharing options...
amarsi Posted May 26 Author Share Posted May 26 Thanks. After several attempts (I'm not good) the problem was solved. Then updated to version 1.88 the problem did not appear. Thanks again, this had never happened in 11 years. Always cheers BitComet and all the staff. Quote Link to comment Share on other sites More sharing options...
