panzer commander Posted August 9, 2006 Share Posted August 9, 2006 :angry: HI!!! I AM NEW.......... SO BE GENTLE!!! OK I HAVE DOWNLOADED BITCOMET 0.07, AND EVERY TIME I DOWNLOAD A FILE FROM ISOHUNT, I SAVE IT, OPEN IT, AND I GET THE INFO ON MY BITCOMET PAGE BUT THEN NOTHING!!!!!!!!!! WHY DOES IT NOT START DOWNLOADING??????? AT THE BOTTOM OF THE PAGE IT SAYS DHT NOT CONNECTED!!!!!!! WHAT THE **** DOES DHT STAND FOR AND DO??????? AND THE LAST THING I WOULD LIKE TO KNOW IS, WHY IS IT ON MY BITCOMET PAGE I CANNOT CONNECT TO ANYTHING ON THE PAGE, JUST KEEPS SAYING CANNOT DISPLAY PAGE. PLEASE HELP :blink: :angry: :blink: Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 9, 2006 Share Posted August 9, 2006 DHT stands for distributed hash table, its a way of having the peers perform the function of the tracker. This is not required to use bit torrent protocall, and some trackers do not allow using of dht. As for your torrents not working, are you using active torrent? or do you know that a torrent has to be active to work? If there are no seeds present, it will never download. I suggest you find an active torrent and confirm if there is really a problem with your setup, or if you have just chosen dead torrents, then we can help you better. If you would like to learn more about bit torrent protocall, have a look here... http://en.wikipedia.org/wiki/Bittorrent Suspect Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 9, 2006 Share Posted August 9, 2006 Also, try to be explain your problem in the title not "HELP!!!!!!!!!!!" I need help with xxx would have been better. Internet curtesy, typing in all caps is like shouting. So you shouldn't do it. Link to comment Share on other sites More sharing options...
mrpopo Posted August 9, 2006 Share Posted August 9, 2006 My Internet connection is of 256Kbps and my bitcomet download does not show my speed connectiong, I know it's not very fast but limewire does better (like 30 Kb/s), but I preffer Bitcomet cause I can find everything by torrents. (I already set Max down:32, and Max up:8, according to my speed) So I need help to improve my downloading speed in Bitcomet, in Bitcomet my speed downloading rate is of 0Kb/s to 5Kb/s. Help!!!!!!! :blink: Link to comment Share on other sites More sharing options...
bitbybit Posted August 16, 2006 Share Posted August 16, 2006 Hi.. I'm having a similar kind of problem.. I have selected a file with over 500 seeders and 25 leechers.. and still the download doesnt begin! The same DTH Not connected message.. Dunno what to do.. so help, please? Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 16, 2006 Share Posted August 16, 2006 The two of you should go through our guide and double check all your settings. Make sure you're using the fully updated version of BC. Make sure your software firewalls allow full access to the web meaning outgoing & incoming aka server access. Also make sure you allow TCP & UDP connections. If you have firewall routers go to www.portforward.com and look up how to configure them. Link to comment Share on other sites More sharing options...
