kstearns86 Posted November 15, 2006 Share Posted November 15, 2006 Okay so I just downloaded BitComet yesterday... I've tried downloading from www.torrentspy.com and Torrent Pond... either way, my downloads NEVER download. They just sit there idle and reconnect over and over. I even left them overnight last night, and no progress whatsoever. Is there something wrong with my connection or should I just try some other program to download music? Quote Link to comment Share on other sites More sharing options...
kluelos Posted November 17, 2006 Share Posted November 17, 2006 You might try configuring your client. There's a whole separate forum for problems with the BitComet client, and in it, there's a settings guide to tell you how to configure BitComet. If you read and follow it, that should solve your problem. Quote Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted November 17, 2006 Share Posted November 17, 2006 Another common mistake new users make is selecting torrents that are no longer active. If there are no seeds/peers, it will never start. If ther are no seeds, but has peers, it may never finish. Try one of these torrents if you want to see if your client is working... http://distribution.openoffice.org/p2p/index.html Suspect ps. be sure to read our guide "New to bit torrent" by Soriaya Quote Link to comment Share on other sites More sharing options...
