wondeer Posted August 3, 2014 Share Posted August 3, 2014 (edited) Hola a todos, soy nuevo en los foros de Bitcomet. El problema que me preocupa, creo que se debe a un problema de incompatibilidad entre la versión 1.35 de bitcomet y el plugin de emule versión 1.24 (tanto en el modo xtreme, como en la versión normal), ya que en versiones anteriores de Bitcomet, la misma versión del plugin de emule me funcionaba muy bien. El plugin me da mensajes de error, de que el sistema no puede encontrar el archivo especificado, que si ha habido un fallo al crear un determinado archivo (por eso no se puede encontrar), etc; así que me introduje en el directorio de Bitcomet y pude comprobar, para mi sorpresa, que en la carpeta "plugin_emule", faltaban muchas carpetas que no se habian instalado durante la instalación del plugin, con lo cuál no me extrañaba para nada que el emule no funcionara y no se conectara. Bueno, espero una solución. Gracias. Hello everyone, I'm new to the BitComet forums. The problem that worries me, I think, is due to an incompatability problem between version 1.35 and the eMule plug-in version1.24 (both for the Xtreme mode as well as for the Normal one)... as in previous versions of BitComet, the same version of the eMule plug-in worked very well for me. The plug-in gives me error messages - the like of 'the system can't find the specified file', 'an error has ocurred when creating a specific file(that's why it can't be found), etc. . So, I accessed BitComet's directory and was able to see (to my surprise) that in the "plugin_emule" folder many folders were missing - they hadn't been installed during the installation of the plug-in - therefore, I wasn't at all surprised that the eMule wouldn't work and would not connect. Well, I await a solution. Thank you. Edited August 3, 2014 by cassie (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 3, 2014 Share Posted August 3, 2014 (edited) I'm using BitComet version 1.37 and eMule plugin 1.24 and it seems to work fine. Yo estoy usando la versión de BitComet 1.37 con el plug-in de eMule 1.24, y parece funcionar bien. Edited August 3, 2014 by cassie (see edit history) Link to comment Share on other sites More sharing options...
wondeer Posted August 3, 2014 Author Share Posted August 3, 2014 (edited) Gracias por la información The Unusual Suspect, ahora mismo voy a instalarme esa versión. Thank you for the information, The UnUsual Suspect - I'm going to install that version right now. Edited August 3, 2014 by cassie (see edit history) Link to comment Share on other sites More sharing options...
wondeer Posted August 3, 2014 Author Share Posted August 3, 2014 (edited) He instalado la versión 1.37 y continuaba con los problemas. Al final, se me ha ocurrido poner en la pestaña compatibilidad en propiedades del acceso directo de bitcomet, ejecutar como administrador, y ya funciona otra vez, sólo que..., la red kad no se conecta (y eso que tengo los puertos abiertos, como siempre sin ningún problema), cosa que antes, cuando todo iba muy bién, se conectaba sin ningún problema. Así que no sé que puede ser. Yo aparte, tengo el emule MorphXT y me va de maravilla. Si a tí The Unusual Suspect, ó a alguien más, se te ocurre algo, lo agradecería mucho. Un saludo. I installed version 1.37 and continued with the problems. Finally, I thought of choosing to [enable] the option of 'Run as Administrator', in the Compatibility tab in the Properties of BitComet's direct access **, and now it works again...but... the Kadnetwork doesn'tconnect (and I have the ports open, as always and without any problems)... something that before, when everything worked very well, would connect without any problem. So I don't know what it could be. I, also, have e-Mule's MorphXT and it works flawlessly. If you, The UnUsual Suspect, or anyone else thinks of anything else, I would appreciate it a lot. Greetings. [** - I may have gotten these a little mixed up, as far as the order goes...sorry...let me know if it's waayy too far off - cassie] Edited August 6, 2014 by cassie (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 7, 2014 Share Posted August 7, 2014 (edited) You may have to update your server lists. I believe the plugin comes with the default list from when the equivalent version of emule was released and could be outdated but I'm far from an expert in using emule. I have rarely used it independent of BitComet. Es posible que tengas que actualizar tu lista de servidores. Creo que el plug-in que viene con la lista por defecto es el que estába disponible con la versión equivalente de eMule cuando se lanzó, y puede que esté un poco desfasada, pero no soy un experto en cuanto usar eMule.- de hecho, casi nunca lo he usado de forma independiente de BitComet. Edited August 9, 2014 by cassie (see edit history) Link to comment Share on other sites More sharing options...
wondeer Posted August 10, 2014 Author Share Posted August 10, 2014 (edited) Gracias El Unusual Suspect por intentar ayudarme. El caso es que al instalar el plugin no se encuentra ningún servidor, y tengo que añadir manualmente la lista de servidores, entonces cuando me conecto a eD2K, el plugin se conecta sin ningún problema, hasta con ofuscación; pero es en la Red Kad que intenta conectarse y nunca lo logra. Supongo que ya sacaran una nueva versión de BitComet que arregle esto, así que una de dos, ó espero a que salga, ó vuelvo a la antigua versión en la que el plugin me iba muy bién. Un saludo. Thank you, The UnUsualSuspect, for trying to help me. The thing is that upon installing the plug-in, no server can be found and I have to manually add thelist of servers. Then, when I connect to eD2K, the plug-in connects without any problem - to the point of obfuscation - but it's with the Kad Net that it tries to connect and never succeeds. I suppose that they'll come up with a new version of BitComet that'll fix this so, I'll either wait until that happens or I'll revert to the prior version in which the plug-in worked ver well for me. Greetings. Edited August 14, 2014 by cassie (see edit history) Link to comment Share on other sites More sharing options...
cassie Posted August 14, 2014 Share Posted August 14, 2014 *translation completed* Link to comment Share on other sites More sharing options...
