kisaku Posted July 31, 2006 Share Posted July 31, 2006 when I use Bitcomet, after while that SERVER BUSY messange pop up and said some crap. only choice I had is 3 button: Switch to---------->switch to what? after I click it just pop out my START MENU! Retry-------->such a crap either,nothing happen after I click it. BITCOMET, 7.0 I am using XP SP1 right now, and not yet upgrade to SP2. no virus sign, after using kav, TH,ewido etc....nothing find. no sign for plug-in active X too computer:( uh.....I don't think that is the matter, but in case....) AMD 3500+ ath 80G SATA 1G kingston dual ASUS A8N5X COMCAST cable. Quote Link to comment Share on other sites More sharing options...
XSTREM Posted July 31, 2006 Share Posted July 31, 2006 Sorry, but I don't know what you're talking about.. Where do you see "Switch to" and "Retry? A screenshot would be great. Quote Link to comment Share on other sites More sharing options...
kisaku Posted August 1, 2006 Author Share Posted August 1, 2006 before after click switch to: donno what to cause those problem, but just hope anyone who have same problem like me. Quote Link to comment Share on other sites More sharing options...
dimchopicha2003 Posted August 1, 2006 Share Posted August 1, 2006 we cant see anything zoom the error messages only Quote Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 1, 2006 Share Posted August 1, 2006 these screenshots are so small I cannot read them, and when I download and zoom in, it still cannot be read. I suggest you provide links to the full size images at your photobucket account. Suspect Quote Link to comment Share on other sites More sharing options...
scarecrow_76 Posted August 1, 2006 Share Posted August 1, 2006 i have this problem a lot too. it is usually a pop-up that gets screwed up some how. i usually click on the switch to button, and wait a minute or to for the pop-up to display. you may have to hit the switch to button a few times. if all else fails hit ctrl+alt+del and try to close down whatever program isn't responding. if that doesn;t work just restart your computer Quote Link to comment Share on other sites More sharing options...
realutd7 Posted August 1, 2006 Share Posted August 1, 2006 just fyi, if you want a better screen shot which is bigger and the file size isn't big, try this... - press "Print Screen" (duh!) - then open up a program like "Paint" - paste the picture - then just below the "File Name", make the "Save as type" into JPEG u will get a good size picture and the file size won't be too big Quote Link to comment Share on other sites More sharing options...
bitdave Posted August 1, 2006 Share Posted August 1, 2006 This problem has come up many times and I dont think anybody has a real solution. It's probably caused by some other program on your computer What antivirus / firewall software do you have on that PC??? What other programs do you run that access the Net??? (AIM, MSN, etc) Do you have any programs like Netlimiter on the PC??? In Bitcomet what do you have the "Max half open TCP connections" set at??? What do you have the "Socket start interval" set at??? Quote Link to comment Share on other sites More sharing options...
kisaku Posted August 1, 2006 Author Share Posted August 1, 2006 hmm...... is 93f outside..... there is no need to post bigger screen shot for reason, I am already fix this problem. the troble is the firewall, sometimes it block the torrent. and my A8N5X had nForce----->have on-board firewall. (donno what exactly happen on the problem, but all I know is after I done this and the pop-up never(yes,NEVER) came back to bother me again, so it means I fix it?donno, because now report my drive is overheated......Orz) DIY to fix this pop-OUT nightmare: just pick the porT SUCH LIKE 18982 OR 19882 etc,(in bit comet) and to your firewall section, either build-in on windows SP2 or McAfee etc, use the same port you pick up just now, and let it set as ALLOW all link connet from out/in..... after I do this, 3 down load is around 50~80 kb, not bad.... (but new problem is:my Seagate SATA get overheated .....;)) thanks for help. Quote Link to comment Share on other sites More sharing options...
